It looks like it should be working but nothing shows up on any device I play the tracks on.
Any help would be greatly appreciated!
There are so many threads in this forum - see e.g. here
Hello everyone!
I'm new to this app, and I was trying to edit the tags of a song. When I was done, everything was properly saved, including the cover, or so did the app said. But when I tried to listen to the song in my mp3, the cover wasnt showing, but the other cathegories were there. What did I do wrong??
Thanks in advance
and try the search function.
A good idea would also be to follow
If you need support using Mp3tag, you can help the community members that are about to support you in finding a solution or workaround to your problem, by following these simple guidelines.
Be descriptive, also in what you’ve already tried
Please give a short explanation what’s not working as expected or what you’re trying to achieve. It’s best to know any details about the problem at hand and especially, what steps you’ve already tried to solve it by yourself. Helpful information also includ…
These are wav files, most players see limited or no metadata with them. As a test, try converting to any other lossless format (FLAC or ALAC) and see what happens then.
