...in the names of the fields that were formerly above the horizontal line that separated the 'fixed' fields from the others. These apparently were not written as the field name for the corresponding values when tagging a file, and it is simple to remove them using the "Edit Field..." tool.
While it's not even a minor problem in practice, it is a bit messy.
I would rather have that ALT+ activate and deactivate the defined tag field instead of to just switching focus to such field
I know that for some time we have the ability to more quickly activate and activate fields in the Tag Panel [with a right click menu activated when the click is performed within the Tag Panel]. But nevertheless if I could even more quickly [with a defined shortcut] turn off some field that happens to be a multiline, then I could have such tag field be turned off 99.9% of the time- thus saving space. I would use it for all those fields that I need to see very rarely- because I tend to turn off what I do not need as I always want to preserve / optimize the precious space, so that I can see as much of data / files as I can on a single screen without the need for scrolling
i'm totally lost. see my screenshot. 1. are these not the default tag panel values mp3tag has on a fresh install? if so, not "user" defined, b/c i, the user, didn't do them, right?
and 2. aside from that, i read your link, but i'm too thick to understand it. why are there ampersands randomly in the setup for these default fields? what purpose do they serve, esp if they can be removed without harm?
As per the linked help article the ampersand defines the letter that will select the field when the Alt key is also pressed. Eg: &Year means pressing Alt + Y will select the Year field, when the Tag Panel is focused, since the & is placed before Y.
Removing the ampersands simply removes the Alt hotkeys.
As for whey those fields are called 'user defined' it's since the default fields are now customizable. Until the more recent Mp3Tag versions the default fields couldn't be customized. All of them now are (which is nice to have) including the default Alt hotkeys which are now exposed to the user.
