- Is there any way to change the default 500x500 artwork resolution that the program searches for?
- Can we add more places to get cover artwork from?
You do not tell us, which web source script you use.
And: here /c/web-sources-scripts
you find many more web sources, perhaps one of your liking.
Whatever the default is. Didn't know this had anything to do with a web source script. I'm just seeing this as software that has a feature that I use. I don't know anything about its programming.
I do not ask this without purpose as the "default" depends on the last web source script you called.
The source is usually mentioned in the dialogue title.
When I select Cover Art, the only options I get are Amazon.com and Amazon.de. It says, CoverArt#Amazon.com. I have a search string I use online that lets me search for artwork of a certain size in google images. I'd love to be able to use that here.
Here is a link to the Google images web source script:
/t/11166/1
Thank you. I don't see anywhere in that string the option to search a minimum px by px?
Oh, I thought you had a string to search for a certain resolution with Google. You may be able to adapt the script.
I habe a special URL search string, yes. But entering it into mp3tag just brought up an error.
Where did you enter that URL search string in Mp3tag?
I followed this... [WS] Google Images Cover Search
