Audiobookshelf use
I have about a dozen audiobooks that have been burned digitally, but the file names are all over the place and I want to get them in order so I can store them in my drive and listen to them using Audiobookshelf in my car.
However, I don't know an easy way to get them named so they're in the correct order for listening. Can I do that using Mp3tag?
Have you filled any tag fields?
I haven't tried using it at all yet. I'll try and see what I can do when I'm back in front of my computer. Then I will write back with more questions, if needed.
Perhaps you could wrap your questions in the
OK. I'll do that. Thanks for the feedback.
