Auto Adding a Space After a Period
#1
Hi all wondering if someone knew how to have mp3tag always make sure there is a space after a period.
For example:
Jowell Y Randy - 15. Rastrillea (Ft.Los Leones) (Official Remix).mp3
Changes to this:
Jowell Y Randy - 15. Rastrillea (Ft. Los Leones) (Official Remix).mp3
#2
Please :book: Aktionen
If you can't translate it to english, just let us know...
#3
FAQ is also available in English...
Actions
#4
Danke, dano!
Ich hab die noch gesucht, aber leider auch mit Sprachwahl "englisch" landet man bei klick auf FAQ (links von Hilfe) auf die deutsche FAQ. :sunglasses:
#5
Faq doesn't really get into how to automatically have a space added after a period. Are both faq's the same?
#6
Maybe an action like this:
Replace with regular expression
Regular expression: .([^\s+])
Replace matches with: . $1
You can try it, I'm not exactly an expert with the actions and/or RegEx though, so I would thoroughly test it before running it on a large amount of files.
#7
Yes FAQ doesn't help because a simple replace doesn't work.
The RegEx of Mizery_Made is also not good if you apply it to a filename because it also adds a space before the extension. (And why the + sign?)
Edit. Ok we just put the RegEx in a different action:
Action type: Format value
Field: _FILENAME
Formatstring: $regexp(%_filename%,'.([^\s])',. $1)
#8
Right you are Dano :\
#9
Wow thanks guys! That was REALLY complex don't think I could have figured that out at all.
Thanks both Dano and Mizery_Made for your efforts :slight_smile:
