Auto Numbering and leading zero # in explorer
Have looked through support pages but still can't figure out the problem with leading zero's
Tracks number correctly if only up to 99 in file but say 103 tracks and window displays duplicate 8 or 9 numbers etc
believe this is a old problem with explorer is there a way around this
At present I number tracks 1 to 80 with auto number no leading zero then select 81 onwards so as display continues with the leading zero and # gives proper track number in Explorer
Ian
see e.g. here:
I doubt that there is another way around it than to save numbers that they do not have leading zeros when there are 3 digits.
