Can you make possible to automatic read file in folder album
Or add a shortcut to add album picture.
Thanks
There is already a "shortcut", called Action:
And not to forget:
You can always drag & drop such a folder.jpg artwork to one or multiple selected tracks and save it.
If in File->Options->Tags->"Don't display first image from the directory as cover art" is unchecked, MP3Tag will show folder.jpg, if it's the first or only picture file in the album folder.
This looks very similar to this topic:
and that got a solution as far as I can tell.
