Hi
Is it possible for MP3Tag to calculate the length of selected mp3's and update the LENGTH field in the tag via an action (or a batch mode)
Reason for this question is that the XBox 360 only displays the duration of a mp3 when the LENGTH tag is present.
Regards
Yes, it is possible.
If you speak about duration in seconds, then you can use the %_length_seconds% system variable, which contains the length of the music part of a file in seconds.
This length is a value rounded to seconds, not an accurate value of samples or fractions of a second.
Create an action "Format value" for the tag field LENGTH and use %_length_seconds% as format string.
Run this action against each file you want.
DD.20100320.1213.CET
Thanks for the prompt reply, this solution works great.
Note that LENGTH fields holds milliseconds so I had to multiply %_length_seconds% by 1000.
$mul(%_length_seconds%,1000)
