Hi, it seems that mp3tag is not able to adjust some covers.
What is anybody supposed to do with such a global statement?
Please supply a lot more details.
I've sent a file to @Florian to test it!
Mostly these files are coming from the same source.
For an unknown reason the cover size is ~20MB and the resolution is 5000x5000
See this thread on the maximum size of pictures:
(and so it is most likely no MP3tag problem)
I found another file with the same problem...
The cover size is 1MB and the resolution is 1253x1253.
I'm uploading it now for @Florian
Thanks for the example files. The images are using the CMYK color model, which is only barely supported by GDI+, the image library I'm using.
You're already seeing the issue in the Tag Panel, where parts of the image a drawn in black. You'd need to resort to an external application and adjust the covers manually.
I'm also moving this to #support and adjusted the topic title. I'm treating it as a limitation of the feature and it's on my "won't fix" list.
Thanks for the support @Florian.
You are right about the black part, i was wondering why this could be happening!
