Combining Multi Discs Albums Into One Album!
Hi, I was told MP3Tag would do this but not finding a step by step approch.
My situation.
Mac running Tahoe
Audirvana Origin player
Rip CDS with dBpoweramp
I make sure and actually triple check I rip the cds to be say 1/3,2/3,3/3. When looking at actual files in folders numbered with tracks per disc, 1-01...etc..2-01...etc..3-01 BUT they all appear as three separate albums! Does this in iTunes/Music as well some some sort of tag is off.
I tried renaming the tracks, not file name which can have a track#, so instead of 3 discs with 10 tracks each being 1-10 3 times but 1-30. BUT even with syncing and restarting audio players still show up as 3 discs/albums. I even combined into one folder with the track names and still seen as 3 albums.
I have about 100 albums that do this.....way to many to do too much by hand...
Thanks!
Files that should belong to the same album should have the same data in the fields ALBUMARTIST and ALBUM.
For more detailed suggestions please follow
Would this mess it up? Just noticed this album of two discs has album names as:
Dave's Picks Vol-57 - 1978-02-01 Chicago Uptown Theatre
Dave's Picks Vol 57: 02-01-78, Uptown Theatre, Chicago, IL
I just ripped it and this is how dBpoweramp named them.
Can I just change to one or the other...? They are in one folder...and actaully 3 discs that appear as two I suppose due to the album name discrepency.
Thanks!
I do not think that the data from online sources is the sorcerer's stone - which means that you can name the albums anyway you like so that they fit your collection best.
Please do not mix filenames and tag data - they are different things. The filename only has to be unique, the tag data is usually interpreted by the player to group files together and show the tracks at all.
Yes it appears that having the files names for instance 01-jack, 02-bob, 03-kevin has NO bearing on track numbering! So file 02-jack can be track 12 if I prefer...correct???
Only Mac finder will use file name as a name sort.
I'm convinced this is a dBpoweramp issue as I pay VERY close attention when ripping as I KNOW the problems it can cause but more than half my rips have similar issues.
I have been using dbpa for a long time. Some of the metadata sourced online is reliable, some is not. I find I have to make edits occasionally to follow my preferences. .
AFAIK dbpa collects the tag data from various sources, including community driven ones - which means that the quality relies on the input by people like you and me. So I do not believe that the results are 100% uniform and accurate. The general gist is ok but the details have to streamlined with programs like MP3tag.
