Sorry if this question has been answered... but The comments that I put in MP3Tag aren't showing up in Virtual DJ. Anyone know if there is a setting that I need to change? or another field that it may be going to?
You have to look which tag-field your software uses for this comment or whether it uses a tagfield at all and not uses it's own database instead
Look for a file which has a comment you can see, load the file into Mp3Tag and have a look with the extended tag-view ALT+T whether you can see the content in a field.
If yes use this field for comments in Virtual DJ.
Just a little research to support what @poster has already described:
You may also want to consider this, if your files are already in the VirtualDJ database:
After a file is loaded into the database, meta data is taken only from that library. Any later changes or additions to a file made in an external tag editor are ignored.
However, there is a procedure to update the VirtualDJ database to include external changes. It's called Batch -> Reload Tags and was posted here by @LyricsLover. See his reply linked below for a screen shot . Scroll down, towards the end of a long thread: Set rating for import in VirtualDJ
That did the trick… I didn’t realize they were already tagged. I have been through hades and back trying to make a new system work that doesn’t have all the dups.
Thank you all!
