Greetings,
I Like To Have The Composer Information On My Tracks.
I Enter It Save As Always And On Multiple Instances It Will NOt Save The Composer Information At Anytime?
Any Help Would Be Appreciated!
Cheers,
TFM
Greetings,
Cheers,
TFM
Perhaps you encounter something like this:
Can you please share which version you're using and the contents of the usrfields.ini from %APPDATA%\Mp3tag\data?
I am having a similar problem, except that nothing I enter in the any of the fields get saved. I am working on windows 10 using mp3tag v2.88a. It was working fine two versions ago, but now it's not saving at all. I am new to using this application, but it did work fine before. Please help.
Please check if you have APE tags in the files.
You can see that e.g. in a column fairly far to the right.
Or apply this filter:
%_tag% HAS APE
If you see files in the files list with APE tags then remove the APE tags.
My Composer Field Is Blank
When I Select < Keep> Still Nothing Happens?
Tried To Attach A Screen Shot But Wasn't Sure How?
Totally Love The Program!
Cheers,
TFM
What happens if you update to the latest version?
