Hello, I searched and saw another person with this same issue but there was not a resolution. I am trying to change the metadata in a group of movies files that have an improperly tagged title. My filenames are good so I am trying to use the feature Convert Filename-Tag to change the Title tag. It works but takes 30-40 seconds per file. I am working on files from a locally attached hard drive on windows 11 - it is a plex server but I closed the server but no change in performance. Any ideas on how to improve this?
I wanted to add one more thing I just noticed. I opened task manager and Mp3Tag is using my hard drive at 150MB/s during the entire retag process - my assumption here is perhaps it is duplicating the entire file to make the change to the title metadata?
You cannot modify the padding.
It its added initally and then is increased each time it is not large enough.
So, if your converter did not add any or too little padding, then the file has to be rewritten.
