Hello everybody!
A problem I am facing is being lazy with putting multiple artists into the filename.
It's easy with ID3v2.3, since it's one artist field where artists are seperated by a character ('/').
This character can be replaced when converting the tag into the filename.
However, with the FLAC format it's a second, third or more field:
ARTIST=Artist1
ARTIST=Artist2
So this required me to look around a bit more for a good way to do this.
I found the following solutions in order:
What I was doing first for ID3v2.3:
$replace(%artist%,/,' feat. ')Then I did this for FLAC:
$replace($meta(artist),',',' feat.')Then I tried tackling both in one:
$replace($meta(artist),',',' feat.','/',' feat. ')As you can see, with more variants of multiple values, the solutions get longer.
So I figured out a better solution to this (my current solution):
$replace($meta_sep(artist,'/'),'/',' feat. ')This still isn't what I'm looking for, since this is a solution for ID3v2.3 (separation character '/') and multiple tags of the same kind (which is the case with FLAC).
And that's annoying right? Having to figure out what kind of separations there are for every format. I think ID3v2.4 uses a 'NULL' to separate values, so I'm guessing that would not work with my current solution.
So is there anyone out there with a better solution?
Otherwise I'd like to suggest a new feature:
$separate_by(placeholder,string)Example:$separate_by(%artist%,' feat. ')
Mp3tag should know how the field is separated with multiple values for every tagging format.
Then I would simply say what string I want the values to be separated with.
