I agree that it would be nice to have a a more flexible option for C&P. But I would wish it for all tags. Often I want to copy only some of the tags and often it is something like UNSYNCEDLYRICS where if I have to use the tag-panel or the extended tag-view because there is no way to set equal content to marked tag-fields.
Well, the undo fn works with artwork too, but it doesn't work seperately.
I use foobar2000s select copy and paste field method if I'm stuck for more than one fleld.
That has been mentioned countless times before. So I didn't bother. But I do agree, if foobar can do it so can this amazing app.
The artwork for me is slightly different because more often than not the copied files have all my organised tags and it's the artwork that's the deciding factor when pasting.
Just to clarify: you can Copy covers via right-click on the cover art window and paste it to other files. Is this something that would be working for you?
