Cover Art and Filename
If the title and the cover art is the same why can't you guys make a program that inserts the cover art automaticlly
Well, you could.
There is an action to import covers.
Enter as filename format string: %title%.jpg
Sorry I don't understand...
Ex: B.B. King - Rock Me Baby - Kent 393 Song
B.B. King - Rock Me Baby - Kent 393 Title
I don't understand either: I thought this was about the external picture file that should be embedded in the file.
To embed a picture you can use an action.
If this is not the case, please explain again more elaborately.
The song and the label are in the same folder.
Thank you for your time I appreciate it
Is this the filename or the tag field TITLE?
Is this what you use as synonym for the picture file that should become the displayer cover? I ask because there is also a tag field called LABEL ...
The "HowTo" section in this forum tells you how to create an action:
Something similar can be found in the help:
In the help you also find a description of the action to import a cover (picture) from an external file.
You fill find that you have to either enter a fixed filename or one that is created dynamically from tag field variables.
Depending on whether you quoted the filename or the tag field TITLE when you mentioned
you enter as
Format string: %title%.jpg
or
Format string: %_filename%.jpg
Try it with a test file.
The song
They are both filenames
OK, then use
Yet, I don't understand why you embed the cover but do not fill the other tag fields.
I did this about 15 years ago as I have the whole Billboard
Top Pop Singles 1955 to 1990 on 3 Hard drives this is why they are in the same folder
Where do I do that
Do you know that you can retrieve data from the filenames to put it in the tag fields?
See the function Convert>Filename-Tag
