When I change the cover of a file (adding a new cover, removing current cover) and move to the next file in the list before explicitly saving the cover changes with Ctrl+S or the toolbar "Save" button the changes are lost.
When I edit a text field in the list instead the changes are saved when moving to the next file. I think both editing options should work the same way and save the changes when moving to the next file!
You could activate File -> Options -> Messages
"Show message at unsaved changes"
Then you will see a confirmation box for every unsaved change.
Please also check your settings in
File -> Options -> Tags
"Save tags when using arrow keys/single mouse click"
This is checked, but does not have any effect on changed cover images. No notification appears when moving to the next file.
This is also checked. When I edit a text field the new contents is saved when moving to the next file, but changed cover images are not.
I can't confirm this behaviour with my Mp3tag version 3.11e.
BTW: What exactly do you mean with "moving to the next file". Do you use the key up, key down-arrows from your keyboard? Do you use your mouse? How exactly do you "move to the next file"?
Which Mp3tag version do you use?
Tried in in Windows with several combinations of settings.
As soon as I set the option to get a message at unsaved changes, the changed cover is also saved.
So, same as @LyricsLover.
Giving up on this and moved to #support
