wroj_k
1
I cannot figure this out.
No "create playlists" button,
No File>export..
File>Save is greyed out, trial version limitation?
Other playlist topics mention keyboard shortcuts (e.g. ctrl+shift p), that don't do anything for me.
Just not possible in the OSX version?
OSX 10.5.7
MP3tag Version 1.1.1-trial (44)
Creating playlists is currently not possible and I'm working on it for one of the next versions. I'll keep you posted
No, you'd need to do a change on the Tag Panel for the Save function to be enabled.
wroj_k
3
Hi Florian,
thanks for the speedy reply.
ok, got it, thanks.
I've just released Mp3tag v1.2.0 that supports creating playlists and exporting to text and CSV files.
