I would like to use an action to do disc numbering in mp3tag and to show the current disc and with total discs in album
as mp3tag does not know anything about albums you would have.
But if you have the information in the folder structure somewhere, you might be able to recycle that information.
See also this thread on the idea of a numbering wizard:
/t/11387/1
didn't work for me
What didn't work for you?
If the information is not already stored somewhere, you have to supply it yourself.
This could mean the tap the folder names or to use an external program to count the discs. Or simply enter the discnumber.
[/quote]
not very good with this
my folder structure is like this shown in screen dumps ive added
what would I need to put
You could load the folder that has the "Disc1" and "Disc2" folders in it.
Select the files.
Use Convert>Filename-Tag
Format string: Disc%discnumber%\%dummy%
The preview should show that the field DISCNUMBER will get filled.
how do I get total as well 1/2 /2/2
Manually.
Or have a look at
How to set TOTALDISCS and TOTALTRACKS?
Or search for yourself.
As I said: Mp3tag does not know anything about albums so it cannot count the total.
