Hello,
For some reason now when I try using tag sources > discogs artist + album none of the artwork loads from discogs. All the data tags properly but no artwork.
Hello,
It's working fine here. Which release are you observing this with?
I am using mp3tagv327a-x64.
Discogs release is [r739202]
I don't know where I check or how.
You’d know if you were running a firewall or anything else that blocks access to the internet for apps.
I’m out of ideas for now.
Even though this old thread is about Amazon, it might give you an idea where to look also:
Thanks. My ISP haven't blocked me using discogs images as I just tried on a different laptop and it worked.
