Tag Source Discogs Artist + Title does not handle apostrophes in the title (e.g., Eddie Cantor - Ma He's Makin Eyes at Me). I don't know if this is an MP3Tag regex lookup issue or a Discogs issue. Apostrophes in the artist name or album seem to be handled correctly.
Release 3.03 is fabulous. I'm glad to see the much easier maintenance of Action Groups.
If that is the accurate representation of the title then it could be that the correct spelling "Ma He's Makin' Eyes At Me" (with an added apostrophe following "makin") improves the result. Like that the online search in Discogs found the track.
Okay fine. I just picked a random one. Here's another one:
Earth, Wind & Fire - That's the Way of the World
Try this both with title:
and
You'll notice the dramatic difference in results.
There doesn't appear to be an ''advanced search'' in discogs.com ... the instructions tell you to start typing and the option will appear, but it didn't for me. The straightforward search for Earth, Wind & Fire - That's the Way of the World works fine with their basic search (1151 hits vs. 32 for mp3tag vs. 100 for mp3tag without "That's").
If you're pinging the discogs database, it seems as if you'd need some sort of mp3tag scraper, and that scraper would be the first place I'd look for a problem with apostrophes.
But you know your product infinitely better than I.
Be safe.
Only 32 hits also on discogs web search: https://www.discogs.com/search/?type=release&artist=Earth%2C+Wind+%26+Fire&track=That%27s+the+Way+of+the+World
0 hits for the first example: https://www.discogs.com/search/?type=release&artist=Eddie+Cantor&track=Ma+He%27s+Makin+Eyes+at+Me
The problem lies on the discogs search engine.
If we just leave out the apostrophe on the track parameter it seems to give the correct results.
I.e. "Ma Hes Makin Eyes at Me"
Your solution works sometimes, but not for the example above. Try using your regex line with That's the Way of the World (32 hits) vs.the Way of the World (100 hits).
Thanks for this.
DISCOGS also doesn't handle back-accented a's so a further 'refinement' could be: [SearchBy]=Artist||$if2(%albumartist%,%artist%)||&artist=%s||Title||$replace(%title%,'',,à,a)||&track=%s
