When geting tags from discogs release id, first track is allways copied, when I select some other track, this track is visible in discogs window, but when I select ok, tags from first track is copied, my selection is ignored
You have to align the filename in the right list with the track list on the left. Use the arrow buttons next to the 2 lists.
MP3tag does not match filenames with tags.
Thank You, now I get it.
There's also a keyboard shortcut. I'm not in front of my computer right now but I think it is Alt Shift [arrow].
See here for keyboard short cuts in web sources:
