Display multiple values in year field in column view?
I have some files which have a date such as this in the year field "2012 \ \ 2012-02-18" as shown in the tag panel on the LH side.
The column view on the RH side will only show "2012" for that value. It does not show both values.
I would like to trim off the "2012 \ \ ", but I haven’t found an easy way to ID which files have it. The column view is only showing the year.
Thoughts? Thanks!
Edit: Syntax is: $meta_sep(year, \ \ )
You can filter for such files with
"$meta(year,1)" PRESENT
