My m4a files are encoded by Nero, using Mp3tag 2.41a to embed the front and back album art. All album art shows as "Front Cover". If I try to change it, the change shows in the window, but as I soon I press save, it reverts back to "Front Cover". Is this expected behavior? Embedding works fine with my FLAC & MP3 files.
Thanks,
Dirk
Edit: Apologies for not posting in "Bug" forum. I thought that was where I was at until after pressing the post button.
Hi Florian, Thank you for adding the back cover, but I just tried it and I'm getting 2 front covers. After adding, if I try to change to "Back Cover" and save, it still shows both as "Front Cover".
I've tried 2.41b on 3 different computers and I cannot change a second image to anything other than "Front Cover" on any AAC (m4a) files. Can anyone else confirm this? Thanks!
I think it's simply not possible with standard iTunes-style MPEG-4 tags. Maybe Nero has invented some own cover types, but this is beyond my knowledge.
If you send me an example file, I can have a look at this.
C:\foobar2000\Codecs>neroaactag "07 surfin'.m4a" -list-covers
* Nero Digital Audio Reference MPEG-4 & 3GPP Audio Tagger *
* Copyright 2007 Nero AG *
* All Rights Reserved Worldwide *
* Package build date: Aug 6 2007 *
Processing file: "07 surfin'.m4a"
Cover art entry list:
front cover
back cover
End of cover art entries.
No changes made to the file.Also, foobar2000 shows the image as "Back", while mp3tag shows it as "Other".
