How to export the title, artist etc?
to Seperate columns . Please Fix this.
Other programs got this feature. Your Program stills rocks and portable.
File -> Export -> Select csv -> Press [OK]
If you want to change the export format, edit csv.mte in %APPDATA%/Mp3tag/export/
Use a text editor NOT a "Word Processor" or a "Rich Text Editor"
Or you can write your own export format.
Tried that.
Its too complicated. That Way
Which way would be less complicated?
Did you read this post to make it less complicated?
