Here is a Mp3tag export script, which creates a SL split list file, which in turn creates M3U8 playlist files, one for each genre, from a multi value tag-field GENRE.
Tool Mp3tagSplitList
/t/14121/1
Mp3tagSplitList.exe, version 1.01 is needed.
Steps
- Load all relevant folders or files in Mp3tag and select all files.
- Execute the export script ...
"Split List#Export GENRE multivalue playlist to SL file.mte" - When the export file "Playlist.Genre.mv.SL.txt" is located on the desktop, ...
... then call the tool "Mp3tagSplitList.exe" and select the file "Playlist.Genre.mv.SL.txt". - Then in the destination folder there should exist all the M3U8 files, one file for one genre, containing the file paths to the appropriate genre.
- Done.
01: $filename($getEnv('USERPROFILE')'\Desktop\Playlist.Genre.mv.SL.txt',UTF-8)$loop(1,1)$puts(crlf,$char(13)$char(10))$puts(br,'{br}')$loopend()$replace(02: $loop(%ARTIST%'|'%ALBUM%)$replace(
03: $if($neql($meta(GENRE,0),),
04: $get(br)
05: '$$$FILEAPPEND='$getEnv('USERPROFILE')'\Desktop\Playlists\Genre\Playlist.Genre.'$validate($meta(GENRE,0),'_')'.m3u8'$get(br)
06: '#EXTM3U'$get(br)
07: '###GENRE='$meta(GENRE,0)$get(br)
08: '#EXTINF:'%_length_seconds%','%ARTIST%' - '%TITLE%$get(br)
09: %path%$get(br)
10: '$$$END'$get(br),)
11:
12: $if($neql($meta(GENRE,1),),
13: $get(br)
14: '$$$FILEAPPEND='$getEnv('USERPROFILE')'\Desktop\Playlists\Genre\Playlist.Genre.'$validate($meta(GENRE,1),'')'.m3u8'$get(br)
15: '#EXTM3U'$get(br)
16: '###GENRE='$meta(GENRE,1)$get(br)
17: '#EXTINF:'%_length_seconds%','%ARTIST%' - '%TITLE%$get(br)
18: %path%$get(br)
19: '$$$END'$get(br),)
20:
21: $if($neql($meta(GENRE,2),),
22: $get(br)
23: '$$$FILEAPPEND='$getEnv('USERPROFILE')'\Desktop\Playlists\Genre\Playlist.Genre.'$validate($meta(GENRE,2),'')'.m3u8'$get(br)
24: '#EXTM3U'$get(br)
25: '###GENRE='$meta(GENRE,2)$get(br)
26: '#EXTINF:'%_length_seconds%','%ARTIST%' - '%TITLE%$get(br)
27: %path%$get(br)
28: '$$$END'$get(br),)
29:
30: $if($neql($meta(GENRE,3),),
31: $get(br)
32: '$$$FILEAPPEND='$getEnv('USERPROFILE')'\Desktop\Playlists\Genre\Playlist.Genre.'$validate($meta(GENRE,3),'')'.m3u8'$get(br)
33: '#EXTM3U'$get(br)
34: '###GENRE='$meta(GENRE,3)$get(br)
35: '#EXTINF:'%_length_seconds%','%ARTIST%' - '%TITLE%$get(br)
36: %path%$get(br)
37: '$$$END'$get(br),)
38:
39: $if($neql($meta(GENRE,4),),
40: $get(br)
41: '$$$FILEAPPEND='$getEnv('USERPROFILE')'\Desktop\Playlists\Genre\Playlist.Genre.'$validate($meta(GENRE,4),'')'.m3u8'$get(br)
42: '#EXTM3U'$get(br)
43: '###GENRE='$meta(GENRE,4)$get(br)
44: '#EXTINF:'%_length_seconds%','%ARTIST%' - '%TITLE%$get(br)
45: %_path%$get(br)
46: '$$$END'$get(br),)
47:
48: ,$get(crlf),,$get(br),$get(crlf))$loopend()
49: ,$get(crlf),,$get(br),$get(crlf))
Split_List_Export_GENRE_multivalue_playlist_to_SL_file.mte.txt (1.81 KB)(For usage remove the extension ".txt")
DD.20140307.1838.CET
