I noticed something rather buggy when editing multivalve tag. Components are changed arbitrarily.
Tag: Artist
Value Before: Value1\\Value2
Value After: Value2\\Value1
Value1 and Value2, appear in different row in extended view.
I modify Value2 but it moves up unexpectedly.
Am I missing some mp3tag feature? I hope this one has a On/Off switch (defaulted to NO of course).
No it has not.
I don't think that you can set the order anywhere.
BTW: I just edited a track with a multi-value field via the extended tags dialogue and the order stayed, even after closing the dialogue ...
Yes, the order is supposed to stay in the sequence of the individual fields on the extended tag dialog. Please post detailed steps to reproduce the issue in case you observe something different.
These are not detailed steps to reproduce the issue.
Are you editing those fields in the extended tag dialog or is the tag panel or the file list involved also. Are there any contents present before? Are you removing the contents before step 2.
Please make a little bit more effort in describing this if you want me to research this further.
I also tried it with a multi-value field with 3 values.
As soon as I add a non-alphabetic character to an existing string/value, then that value goes to the end of the list.
e.g. string -> string. or stri-ng or string#
This is also true if the value contains a non-alphabetic character and the modification consists of alphabetic characters.
e.g. string. -> shtring.
All these tests have been made in the extended tags dialogue.
