Very good piece of software- thanks!
It would be good to have a feature to replace all accented characters with non-accented versions. I have an Audiotron MP3 audio player which only understands USA characters (ie ASCII 7-bit, first 128 chars). It crashes as soon as it gets an accented char in the filename!
Here is exactly what I'm after- I could do the regexp but it would be v ugly!
http://www.actionscript.org/forums/showthread.php3?t=211442
Maybe an ascii7() function?
This is my convert tag-filename function now
$trim($left($replace($ansi($num(%track%,3)--$mid(%artist%,1,15)--
$mid(%album%,1,15)--$mid(%title%,1,20))
,Ç,c,ç,c,ü,u,û,u,ú,u,ù,u,e,e,ê,e,ë,e,è,e,â,a,ä,a,à,a,å,a,á,a,ã,a,
ï,i,
î,i,ì,i,í,i,Ä,A,Å,A,É,E,æ,ae,Æ,Ae,ô,o,ö,o,ò,o,ó,o,Ü,U,ÿ,y,ñ,n,Ñ,
N
,é,e),60))
In the code above the number of replacements I am using seems to run over an internal limit- if I remove any 3 replacement pairs then the last é to e conversion works. If I leave the function as it is then it does not work.
If I split the $replace function into 2 separate replace functions it works! (see below)
$trim($left(
$replace(
$replace(
$mid(%artist%,1,15)--$mid(%album%,1,15)--%title%)
ï,i,î,i,ì,i,í,i,Ä,A,Å,A,É,E)
,ñ,n,Ñ,N,é,e,!,,'',,'(',,')',,., ,',', ,&,and,':',-)
,60))
It is a tribute to your program that I can even do this (although in this case not so easily
