Would it be possible to create a capability within the application to intelligently lookup releases based off within sub folders of a folder?
For example:
- directory = 2006 > album name
So for all tracks within their respective albums, will be queried as a whole against say, either the beatport or discogs scripts?
Or if you have say a few hundred tracks within mp3tag loaded, have it query all tracks with the same album name and once successfully matched and tagged, automatically move on to the next - querying the next release - offering the user the search results to select from. This would save the user having to continuously select tracks individually run their queries.
I think this would be a really cool feature and help those with large collections trawl through their collections quite easily?
It could be a function that's activated/called upon by having its own menu rather than within the full application as this may not be what users are after all the time?
The functionality/method could something similar to MusicBrainz Picard?
Thank you
