hi everybody, this is my first post here.
i know mp3tag from several years but never used because i'm fan of Tag&Rename but now this app it's old and no longer updated. also i started using mp3tag because i need to copy and paste from 2 different folder in batch all tags from files ogg to files m4a just converted, and mp3tag allows this, while Tag&Rename only makes a copy of a single file and tag
mp3tag is wonderful app but
why can't have tree like file explorer ? just 'Change directory' or 'Favorite directory' but i think file explorer would be more convenient
i need to add sequential tracks numbers to all my files in directory. now i have random tracks numbers like various 1, 5 ... i need add sequential numbers from 01 to 25. how to ?
thanks for reply.
"why" is why mp3tag not have structure like file explorer, like tag&rename. it's great feature and i dont know why (again) an amazing app mp3tag cant have this feature
about track numbering yes ctrl+k work fine, but checked Leading zero for tracknumber i can't get 01,02,03... but always 1,2,3....
Which file format do they have? MP4 files cannot have leading zeros in the track number.
I am not too fond of the "why" question as it asks for justifications from people who do not have to justify their decisions.
In this case, there is an answer to "why isn't there a file tree":
and the way to get a tree is also described in the linked thread.
As the tag field format is a purely numeric one in MP4 files, it does not allow leading zeros - as opposed to mp3 files which have a "numeric string" as field format that allows leading zeros and the slash as separator.
This behaviour is also described in the already linked documentation:
It could therefore be that your old program only displayed leading zeros but never put them into the tag data - which you could easily check if you look at old mp4 files that you tagged with your old program.
If you want to get a display of leading zeros for TRACK in MP3tag, set
Value: $num(%track%,2)
in the column definition.
Regarding the file explorer view, let me give you my experience of moving from Tag&Rename to MP3Tag.
I had used Tag&Rename for almost 2 decades. I changed because I needed more flexibility in my workflow. I did struggle with the lack of folder view as I depended on it for so long. Initially it was almost a deal breaker. It takes a while to get used to a flat view of all the files/tags and now it doesn't bother me at all. I have zero regrets.
maybe. i've tried MP3Tag just because sometimes i need to copy all tags from files from one folder to same converted files from another folder, in batch, and MP3Tag allow this, Tag&Rename copy tag from all selected files but paste just only one
however another little question: Tag&Rename allow tracks numbers in format xx/xx like 01/32. on MP3Tag have this feature ?
You are here in the Mp3tag forum.
Mp3tag respects the existing standards for music files.
m4a does not allow anything else for TRACK then pure numbers like 1 or 11.
m4a does not allow any other characters like / or leading zeroes.
ok right. maybe i can see just in Tag&Rename but isn't real metadata from m4a file. i agree, and sorry for this stupid question, but as another guy says, for me too i used Tag&Rename from several years and now i can see some difference on tag, i need to understand why/how to
If you load a m4a-track (tagged with your old Tag&Rename where you see 01/32) in Mp3tag and then press Alt + T to open the Extended Tags window, what do you see as content for TRACK?
Or could you show us a screenshot from Extended Tags for such a m4a track?
yes, with alt+T i see just one value only (same as default view from Mp3tag). i see xx/xx only in tagrename, but i think isn't real track tag. it's showed just on tagrename. the shot below is from same folder
This would show you 01/25 in the custom column "m4a-Track" because it formats the TRACK number with a leading zero, a Slash / and the content of TOTALTRACKS.
This will only make it look the same in Mp3tag, it will not change the real content!
It also has no effect on how the TRACK and TOTALTRACKS is displayed in other software.
