Hello. I have several file names of mp3's that have 2 numbers in the beginning. how do I batch delete the numbers? A complete step by step like I'm a 3 year old child would help!! example 01 Stayin Alive,01 9 to 5
Lots of examples of this can be found here.
What have you got as data in your fields?
If there is nothing then I would suggest that you import (and rescue) the existing data from the filename first.
As soon as you have data in the tag fields you can easily rename the file with the data from the tag fields.
