That is probably irrelevant, but I will ask: how exactly did you do it?
I make my notes [those extension-less files] outside Mp3tag. But this time on I also turned on the %_FILENAME_EXT% column and removed the extension in Mp3tag- which as it turns out, is impossible: the extension stays there
And if do leave it but change e.g. .mp3 to .mp30, I get in turn .mp30.mp3
With this registry entry
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Winamp.File.MP3\DefaultIcon] @="C:\\MY-FOLDER-WITH-ICONS\\NAME-OF-MY-ICON-FILE-FOR-MP3.ico,0"
I changed icon of my MP3 file format. And I did the same for all of the others audio formats that I use on a daily basis. This results in seeing them also in Mp3tag and leaving the default Winamp icon for formats that I do not use- and so the Winamp icon tells me right away with what I am dealing with. But seeing that icon for my notes in Mp3tag disrupts this system
But I did not
I have white blank icon for those extension-less files. And all of my software shows them as bearing that default white icon- except Mp3tag
That was like the first thing I had checked before reporting this bug
Here is what I have:
*.aac; *.aif; *.aifc; *.aiff; *.ape; *.apl; *.asf; *.dsf; *.flac; *.flc; *.m4v; *.mp+; *.mp1; *.mp2; *.mp3; *.mp4; *.m4a; *.m4b; *.mka; *.mkv; *.mpc; *.oga; *.ogg; *.ofr; *.ofs; *.opus; *.spx; *.tak; *.tta; *.wma; *.wv; *.wav; *.wav;
I know this piece of software, but did not think off using it to check this issue out
As it turns out I have 41 extension-less association [plus 1 * extension], half of which do not ring a bell when I look at to what the association leads to; all of which I do not recall creating. And among them was one for Mp3tag.exe
And so I went to Registry and removed that entry [which was HKEY_CLASSES_ROOT\Applications\Mp3tag.exe]. Even after the reset of the system Mp3tag still was showing me those extension-less files - while at the same time File Types Man no longer shows that entry, nor the Registry. And as it turned out - that supposedly empty entry was not so empty at all: those were my playlists pinned to the icon of Mp3tag on the Taskbar. I had to remove them from it and pin them one more time in order for them to start working again. And after that the File Types Man showed me yet again that empty white icon without extension for Mp3tag.exe being in my Registry [which is also weird because those pinned playlist have their own icon on the Taskbar]
I can drag and drop single file like that or in group with other legit audio formats. And I can also send it as a single file from FreeCommander via Mp3tagButton.exe or also in some group among normal files. I can also use the File > Add Directory option. But what is worth mentioning: if I drop / send / load any other file [JPG, TXT, COM etc.] none of them appear in Mp3tag, but extension-less files always do
