Was trying to switch from Tag&Rename since it hasn't been updated in a while. One feature I hoped to find in Mp3Tag is folder cover art being displayed. But even after unchecking "Don't show files in the file system as cover".I still only see cover art that is embedded in the mp3 files.
Is there no way to see both embedded cover art and folder art side by side, like in Tag&Rename? See attached pic for clarification.
Sure, one of the images--the 200x200--was generated by Windows Media Player back in the day.
I don't use Windows Media Player anymore, but I've kept the cover files in the folder, as I prefer to how my library looks with them than without them--see attached pic for comparisons.
Once in a while I'll go through my older mp3 files and use Tag&Rename to save the embedded album art to the folder, as those images are better quality. I was hoping to use MP3 tag in a similar fashion, but I guess that's not the intended use case. No worries, tx.
You can do this the other way around to get rid of the low resolution artwork.
First I'd use Win Explorer or similar and delete all of the current images. Then use mp3tag to export each embedded cover to the album folder. There is an option to not duplicate the images.
Maybe I'll give that a try. Tag&Rename has been great but looking like abandonware at this point, so should try something that is still being developed.
Thanks!
Just make sure all of your music files have embedded artwork first, in case you need one of them. But frankly the 100x100 and 200x200 thumbnails that WMP stores are really pretty useless anyhow.
