I'm using mp3tag since... ever. And love it of course.
Now i can't install the latest version (3.21). Neither 64- or 32-Bit. The error message "found existing 32-bit (or 64-bit) installation..." appears.
But i already deleted my previous installation and folder. Even the ...\AppData\Roaming folder.
However the Mp3tag (v3.19) app is still shown in Windows>Settings>Apps. When trying to uninstall. here it also says "Can't find C:\Program Files..."
(I'm using Windows 11 Pro)
Which one?
There is no Mp3tag Uninstaller left. The whole folder C:\Program Files\Mp3tag is removed.
If I try to uninstall via Windows>Apps it says "Can't find C:\Program Files\Mp3tag\Uninstall.exe"
I don't know what the new installer exactly checks to return the above error messages.
But could it be that you have Mp3tag leftovers in your Windows Registry (or did you removed them also manually already)?
Ok thanks, i searched and removed every "mp3tag" entry in my RegEdit manually.
...It worked! Installation was successful, program is running and I'm tagging again
This happens if both the 32-bit and the 64-bit version are installed.
In this case, the easiest solution is to just uninstall the "active" version via Windows Settings β Apps & Features and then run the installer again. If it still complains, you need to install the version with the different architecture.
Deleting the installation files manually (including the uninstaller, which is not recommended) added the extra difficulty in this case.
Thanks for your answer, Florian!
I even tried using the Mp3tagUninstall.exe before i deleted anything manually. For some reason it always brought the error saying "Please close mp3tag first"
But the program wasn't running for sure. I checked all processes in the task manager and even restarted the PC.
Maybe i really damaged something with a previous installation or so. Anyway, now it works fine as ususal again.
Happened to me too only on this version for some reason; never had the issue before despite the same factors being involved, but Florian's solution worked perfectly!
