Functionality suggestion: Export to clipboard
I often use export tracklist functionality, especially when adding releases to music databases on the internet.
And every time this looks like this:
  • load album
  • select all files
  • export using predefined settings (format) to temporary file
  • open file with mp3tag prompt
  • copy content to the website
  • remove temporary file
Export content directly to the clipboard instead of file at the disk would be a neat feature in this scenario. And it might be quite easy one to add to the mp3tag :slight_smile:
here is a lengthy discussion plus links to various scripts and ideas:
This is possible with V3.26
