Hi , did a quick search but found nothing ?
I'd like to have some defaults in the genre field > Blues , Rock , Folk .
Currently I'm typing in the desired genre every time ....
I'm sure there is an easier way
would a kind soul please point me in the right direction ?
TIA ( Thanks In Advance )
for some reason , most likely operator error , I've no presets , just a blank field .
Please check File>Options>Genres
whether you have set "Only custom genres"
Bingo , thank-you very much
Hi All , Back again .
Sadly the solution isn't permanent .
every time I open mp3tag the genre fields are blank .
this issue is perplexing to me .
when I open mp3tag the drop down list in genres is blank .
I can add user defined genre BUT they do not show when editing tags .
typing in a genre works however this is a tad redundant
So, what do your settings int File>Options>Genre look like?
Have you added any genres there?
poster
11
You have to use the tagpanel to see your user-defined genres, not the extended tagpanel as you obviously do.
Bingo
knew it would be something simple
