Has Quick Actions behaviour changed?
Hi
Just installed v3.32. The behaviour of Quick Actions seems to have changed? E.g. I select the table, ask to replace a column with a new value (e.g. ALBUM ARTIST), but nothing happens!
Have restarted PC a couple of times. This has not helped. Not sure what to do … if Mp3tag has not caused this I need to look elsewhere!
Thanks for reading.
Could you please show us a screenshot of how you are trying to "replace a column with a new value"?
Thanks.
Well: I can try that tomorrow but the procedure is straightforward:
Select the table
Select the Action required from the menu
Select the column to edit (e.g. ALBUM, ALBUM ARTIST etc) . In the case I was referring to this is either FORMAT value or REPLACE value.
Enter the required value to add/replace to the column field.
Press OK and the field is updated with the new value.
That doesn’t seem to be working like that after the update but it worked like that in the previous version.
(Before I turn in (at 23.30) I will reinstall the update just to make sure …)
Update tomorrow …
AhA! Just reinstalled and it now seems to work. Doh! Thanks for help, my bad!
