Help! Tags are not displayed anymore!
Once to a second there are no more Tags in the grid!
The tags themself exist as you can see in the screenshot.
What to do?
Restart of pc didn't help anything. deinstallation and re-installation of Version 2.30a also didn't help.
:w00t: Enno
Since you know German, have a look at this post.
Ha! That's it!
Danke zum zweiten mal, Sebastian!
Greetz,
Enno
I cannot read German so problem might or might not be the same.
All my tags appear in both windows but the Filename does not. For some reason it has disappeared..............last night it was OK, tonight it has gone.
Can someone please advise. I'm using Version 2.30
Thanks,
auldyin
If you go to the columns customization, what field do you see in the Filename column?
View...Customise Columns....Filename....Filename
Is this what you mean?
Thanks,
auldyin
Use "%_filename_ext%" as value and field.
Thank you!
