I'm having a problem getting the correct release date for some music albums.
I am wondering how to change the metadata of a directory of FLAC files.
I have below
In Roon: 21 November 2011
In Microsoft explorer, the directory is labeled Album Name(1970)
In Mp3tag: Year 1970
How do I change so that I get the correct date in Roon; April 14, 1970?
Thank you if someone can tell me how to do it
Are you on a Mac?
To get a more detailed date than
you would have to check where
should come from, e.g. have a look at the extended tags dialogue and see if there are other dates besides 1970.
Also, it would be worthwhile to find out how Roon gets
See also this thread for possible names of tag fields esp. for Roon:
If roon recognizes an album, it can get all sorts of information from its own databases that it reports even though such information is NOT in the file metadata.
