If you want to simply see a value, you can set that in the column definition:
Enter "Music from Joe" in "Value"
Yet, this does not save anything, it just displays.
I've been trying to recreate my settings for mp3tag because I haven't used it in awhile. One of the settings I want to customize is in the comment section. I want to default "MUSIC from Joe". I'd like it to automatically tag and replace anything in the "COMMENT"section with "MUSIC from Joe" automatically.
The feature to set default values has been removed in one of the previous versions.
You would have to apply a dedicated action to write these values.
see e.g. here:
I read the link you sent. That's too bad that this setting is removed
I really liked it.
Do you think you can show me an example on how to create a dedicated action for "MUSIC from Joe"
I don't want to have to enter it all the time or one at a time. I'd like to be able to add it automatically. Can you please show me the workaround?
Thanks for your time ohrenkino
