How do you remove tags of Suno
How can I remove a Suno tag from my songs
I don't know what a
is.
Where do you see this tag?
Sreenshots help in many cases.
Also, following
makes sensible suggestions much easier in most cases.
If you want to know how to remove the fields that the AI music generator "Suno" writes into music files:
You can remove them in the ALBUM or ARTIST fields, just like any other text.
If you show us some real existing example tags from View -> Extended Tags (Alt + T) in Mp3tag with screenshots, we can help you to remove or replace them.
We can also help you remove the "Generated by Suno" text from the file name if you show us some real file names from your collection.
Also if you want to remove the embedded watermark, that can’t be done by Mp3tag as it is part of the audio stream.
For those interested: What Is the Suno Watermark? A Technical Primer
Just to be clear, the linked explanation is not an official Suno source.
As mentioned at the top of the page: "Editorial disclosure: Independent research, affiliate-supported" and in the footer: "Not affiliated with Suno AI, DistroKid, TuneCore, or any DSP."
