How to create an 'enter' in comments
Does anyone know if an 'enter' command can be written into the comments rather than everything being all on one line? For example:
I would like…
Disc 1 - Released 1/1/19Disc 2 - Released 2/1/19Disc 3 - Released 3/1/19
to display like this...
Thanks in advance,
Lee
Use Ctrl-Enter do get a line break.
Please note that in the tag panel you have to set the comment field to "multiline" to be able to enter line breaks.
Do you know how this is done?
Right-click in the grey area of the tag panel and select "Adapt ..." in the menu or use File>Options>Tag-Panel.
There select the entry for Comment and click the Edit button.
In the drop-down list for "Size" select "multiline".
Exactly what I needed. Thank you SO much!!!
:ok_hand:
