I have had a quick look through documentation but I can't see if and how mediamonkey ratings can be displayed and if they can then be edited.
I tried a new column using %rating mm% but that doesn't seem to work for Flacs. I saw talk of mappings but I need a clear instruction as I couldn't figure anything out.
The fastest way to check this on your end is to open the extended tags window for a file you know has these MM ratings. Every tag you can expect to see and edit in mp3tag should be presented in that list.
You can use the shortcut Alt-T to quickly open that window.
In addition: Also set in Ctrl-O>Tags>Advanced Always display POPULARIMETER values for ID3V2 ratings
and check if you have a mapping in the option for POPULARIMETER and RATING.
Thanks for that. %rating% seems to be an editable field. It also seems to match the Mediamonkey one. But updating it doesn't seem to go back to media monkey. Not by itself. But when I updated another field and the results suddenly appeared. I had tried closing and reopening Mediamonkey with no joy. And rescanning the folder. Most interesting.
Oh well. If I can see what Mediamonkey has that helps me and I didn't know there was a general rating field for mp3tag anyway so that is really useful. My main software player doesn't use rating anyway and I have to use Genre hence I am preferring to use Mp3tag.
Incidentally the other rating fields such as %rating mm% didn't have anything in them and didn't show in extended tags.
