Hello,
I am an absolute beginner and faced the following problem on my Mac:
To have the information of certain music files to have been shown correct on my BluSound- Player I needed to re-tag the files. Unfortunately this did not show the result expected.
Therefore I downloaded another editor and faced out that there is a a TAG3 field which included the information which was the cause for me problem.
Now my question - how to I find such hidden Tags. All the research so far did solve my question.
That’s not the problem. I found in the tag a name of an artist (not shown in mp3tag) which my blusound player used for referencing and sorting the artist name. After deleting this field in the other software it‘s ok now.
Even a look into the extended tags did not show the field which was causing the problem.
Thank you for the example file and the extra information. WAV files can have two tag formats and Mp3tag supports both ID3v2 and RIFF INFO tags. It prioritizes display of ID3v2 tags (it's the more capable tag format) but writes, e.g., album and artist information also to a RIFF INFO tag.
So whenever you face one of the mentioned issues again, you can try changing the information in Mp3tag and it should affect both tag versions. BlueSound might need to be triggered to rescan or reindex the files to make the change visible.
Regarding identifying such files: you can use the Filter with %_tag% HAS RIFF to list all files with such tags.
Danke für die Antwort und die Geduld mit einem Neuling.
Ich versuch mal auf Deutsch den Sachverhalt zu erklären. Nachdem ich auf meinem Bluesound Player immer wieder die Auflistung des betreffenden Albums unter einem unerwünschten Namen gefunden habe, habe ich mir eine shareware software geladen um zu sehen ob e eventuell Felder existieren die in Mp3Tag nicht angezeigt werden.
Ich habe dort im RIFF Tag den falschen Namen gefunden und das Feld gelöscht.
Da dieses Feld nicht im ID3v2 existierte konnte es also auch nicht „überschriebe“ werden.
Deshalb meine Frage wie ich in Zukunft solche eventuell existierende Felder editieren kann.
Vielen Dank, Thomas
If you encounter such a file again, please send it to me before you remove the field. This is the only way I can implement support for this field from RIFF INFO tags in Mp3tag and, thus, make it changeable by the user.
German translation:
Wenn Du nochmal eine solche Datei findest, schick sie mir bitte gleich bevor Du das Feld entfernst. Nur so kann ich Unterstützung für dieses Feld aus RIFF INFO Tags in Mp3tag implementieren und es so auch durch den Benutzer veränderbar machen.
Du kannst übrigens für evtl. zukünftige Fragen auch hier schreiben: Mp3tag für Mac
