I updated from 32 to 64bit, can I delete the 32bit version without deleting my settings?
I updated from 32 to 64bit, can I delete the 32bit version without deleting my settings? Thanks!
Hard to say.
Did you follow the notes on switching from 32- to 64-bit?
I did not. Thanks for the heads up. I thought I just hadn't updated in awhile. :sweat_smile:
As it is not quite clear what kind of installation you had before and where that saved the configuration, the safest way would be to proceed as described in the extra notes which I linked above.
Save the former configuration in a separate place, other than the program folder,
de-install the 32-bit version,
install the 64-bit version,
Run it once,
transfer the saved settings to the configuration folder (which you can open with a function in the File menu).
Restart MP3tag and everything should be fine.
