Incorrectly sized layout
Hello,
since several versions I have the following small issue: Fields with a drop down do not display it after opening the program, but only after moving the splitter between the tracks and the tracklist. It looks as this:
For info: I use Win 10 20H2, dispplay resolution 3840x2160, text scaling 150%.
Since I program myself (mainly Delphi), it may be a resolution/scaling combination
Feel free to send me a private message if you need further details
Kind regards Gernot
Thanks for reporting. It's also mentioned here:
I'll try another fixing attempt soon :slight_smile:
Many thanks Florian - looking forward to it. Feel free to reach out if you need a tester
I've sent an internal build with additional debug output via PM. Would be great if you could try this.
This should now be fixed with Mp3tag v3.06b.
