Hi
I have been using '%title% %track%' to insert the track numbers into my song title but they number 01, 02, 03 etc.
I just want numbers 1, 2, 3 4 etc.
How do I do this please.
Terry Booth
Hi
Terry Booth
Do you already have filled your TRACK number?
Or do you want to get it from your current filename into your TITLE?
A screenshot from your current situation would help.
If the field TRACK already contains 01 (for example),
then one way would be using Convert Tag -> Tag with
Field: TITLE
Format string: %TITLE% $num(%TRACK%,1)
Hi Just tried %TITLE% $num(%TRACK%,1) and it works although the number appears at the end of the title. I would prefer this,
Any advice?
Terry Booth
What about swapping the values in the Format string to
$num(%TRACK%,1). %TITLE%
Well that worked.
Thank you very much.
Terry Booth
