juno records
#1
How do I install the script? / Wie installiere ich das Script?
Music type: Dance, Electronic
juno.co.uk_04.zip (3.41 KB)
Re-Instating Cover Art
Batch heterogenous genres?
juno.co.uk
#2
excellent, thank you.
works great, I have just one small request :slight_smile:
for the title would it be possible to grab the whole line, ie on this page http://www.juno.co.uk/products/240141-01.htm track 1 would be;
Bass Pressure (original mix) <without the "'s if possible…
instead of just
Bass Pressure
as it is both tracks get renamed the same…
thanks for taking the time to put this together, tis appreciated :smiley:
#3
Ok it’s changed.
#4
excellent, have stuck a few pence in the donation box :slight_smile:
#5
doh! I don’t think this was there before but I’ve noticed they now have an option to search downloadable music as well.
as it stands these wouldn’t show up and I think the new search path needs to include the show_digital=1;
http://www.juno.co.uk/search.php?show_digi…&column=all
only trouble then is the track names aren’t pulled as the html is different and that’s about as far as I can get.
could you take a look please and see if it’s possible to pull the names from both the usual pages like the one above;
and a results page for a downloadable track/s like;
http://www.juno.co.uk/products/1219652-02.htm
with the same source. with the search as it is at the moment you can’t locate that second page.
cheers :slight_smile:
#6
I’m hoping someone could take a look at this for me.
I’ve updated this script from the original as a lot has changed since.
but now I cannot get it to return more that one entry when searching.
I’ve attached the script as I have it so far and a debug file with more than one search returned, yet as I say, the script only shows the first of these. Probably something to do with the do…while expression.
cheers
bp
#7
hmmm 24 downloads and not one reply…
can I get my donation back? :laughing:
#8
Fixed my script :sorcerer:
#9
Thanks Dano. I’m sure everybody else who’s grabbed it appreciates it too… :smiley:
#10
thanks !
#11
Please exist any chance for xxx.junodownload.com ??? Love your work big thx!
#12
Why, what’s the difference?
#13
Junodownload is more big and contain covers in high resolution 700x700 directly from artist and label’s is to digital source mp3, wav; and juno.co.uk (not working plug src) is to Vinyl covers obtain from a simple scanner never the same quality. Sorry for my bad english and thank’s in advance.
#14
Up :wink:
#15
Hi guys,
I´ve recently installed this script but I can´t get it to work. I can´t get any results results whatever I type in the search box ? Is there something you have to do to get it to work.
Discogs works fine in most cases but I have some albums in my collection that juno have that aren´t listed on discogs.
Regards
Magnus
#16
Download the script again.
#17
Thx dano,
Working perfect now! :slight_smile:
#18
If I for exampel tag the album “DJ Set Volume 82” I can´t get the correct Artist in the arist column in mp3tag. I get the artist in the title column like this.
  1. Ida Corr - “Ride My Tempo” (Deeper People remix)
Looking into this page, it doesn´t seem to split these to in seperate fields either.
http://www.juno.co.uk/ppps/products/337574-01.htm
Any suggestion what to do here ? Do I have to type the artist in manually ? :slight_smile:
Regards
#19
I haven’t implemented this yet in the script, but you can also fix it in another way:
In the Adjust tag information window click on “Utils > Compilation” and enter
%artist% - %title%
to split the title.
#20
My first post here. I use this script a lot! :slight_smile:
But i have a request. Is it possible to add the catalog #?
Thanks
