my file name is like this:
Herbert von Karajan - DG Recordings - 069-01 - (1970) - Beethoven - Musik zu Goethes Trauerspiel Egmont - Op 84 - Ouvertüre.flac
and I would like to have in %track% = 069-01
and in the title :
Herbert von Karajan - DG Recordings - (1970) - Beethoven - Musik zu Goethes Trauerspiel Egmont - Op 84 - Ouvertüre.flac
keeping the " - " between karajan and DG and betwwen recordings and (1970)
Thank you for the sample. I have use the first one and it did work with a slight modification probably because I did not explain well what I wanted to do. Thanbks again it did work fine.
Sorry, my bad, I have neglected that you need the tag-field TITLE to be filled from the filename, but not want to change the filename. I am glad that you have done it right by yourself.
