Actions and batch-operations
How to create a new action?
First, create a new action group via Actions > Actions Actions or Alt + 6.
Then, click on the button New New and give your action group an expressive name, e.g., "All tag fields Upper Case". This action group can be applied to the selected files after you have added one or more actions to it.
Now, you can create a new action in your action group via the button New New and choose the desired action type from the list.
At the moment the following action types are available
You can combine different actions (e.g., Case conversion and Replace) in one action group and activate or deactivate them via the checkmarks in the Actions > Actions Actions dialog.
Mass Tag/Filename Conversion
Action to replace "[ ]" by "( )"
Editing Titles to be 'Artist - Title'
Export Action to txt
duplicate tags
Can i copy a field to another?
How do I do actions/scripts
Do all this in one click?
Batch Removing Part Of The Comment Tag & Adding It To The Album Tag
Working with multiple Genres and Instruments
Batch Edit Album Art from Progressive to Baseline Support?
Create a Master Tag file
Removing (Automating) Slashes
Want to Replace - But Am LOST
Copy TAG
How do you add a custom name to "Comment" section as the defalut?
Help removing question marks and other characters from title
Adding Coverarts to same-name-mp3file
How to execute a script in mp3tag
Capitalize First Letter after (
How to set default desired values in tag field
Looking for New User Help
Discogs Questions
keep seperator in two segment filename to tag
Batch autotag different fields?
Copy a tag field in other tag field, not working!
Extracting artwork to album folder - is that possible?
How to export cover art to directory structure
Year Category Needs Correcting
Adjust Cover ; how where.?
Custom action profiles .mta
Tag-Felder kopieren?
How to I automatically put the second artist into the title
Tag remove problems
Apostrophe vs. Accent aigu
Second Art Cover for Bonus Album
Extract and create cover files for a large number of folders
Titles disappearing
Batch change the folder name based on the tags of the files inside it
My .mp3 files no longer have embedded images
Freezing when trying to get album art
Rename based on certain tag fields incl. regexp
Tag panel option to insert value or fomatted string
Mass Edit of Charactor
Create A New Action to swap first name last name to last name, first name
How to retag using batch file
